Date/Time: Tue, 26 Nov 2024 00:44:48 +0000
Market depth on the edge of the chart
View Count: 177
[2024-01-17 21:36:45] |
Jimmyz83 - Posts: 51 |
Please see attached pic. I am trying to find the setting/indicator etc... and cant find how to set this up. On the right edge of the chart the market depth is showing. Can you tell me how to reproduce it on mine? thanks.
chart market depth.jpg / V - Attached On 2024-01-17 21:36:32 UTC - Size: 20.57 KB - 66 views |
[2024-01-17 22:47:33] |
John - SC Support - Posts: 36286 |
That is called the "DOM Graph". Refer to the following: Chart Settings: Draw DOM Graph On Chart (Chart >> Chart Settings >> Market Depth >> DOM Graph menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
