Date/Time: Tue, 26 Nov 2024 00:26:02 +0000
Number bar
View Count: 146
[2024-01-17 19:37:44] |
User476447 - Posts: 1 |
Hello, I Want to make number bar with negative delta on left and positive delta on right, like the first attached file Thanks for reply. |
52A8DB7B-3D28-4204-BE1E-2F454FAEC9C6.png / V - Attached On 2024-01-17 19:37:39 UTC - Size: 2.4 MB - 43 views |
[2024-01-17 19:47:01] |
John - SC Support - Posts: 36286 |
You would need to use two copies of the Numbers Bars Calculated Values study. Both would have the following settings: - Column 1 Numbers Bars Text: Ask Vol Bid Vol Difference - Column 1 Text Coloring Method: Based on AskVol BidVol Difference - Actual - Use Separate Colors for Text Coloring Method: Yes Then in one of the Numbers Bars, you would set it up for the negative values by setting the following: - Single Value Text Alignment: Left - Range 3 Up Level for Text: Same as background - Range 2 Up Level for Text: Same as background - Range 1 Up Level for Text: Same as background - Range 0 Up Level for Text: Same as background - Range 0 Down Level for Text: Black (or whatever color you want to display these values) - Range 1 Down Level for Text: Black (or whatever color you want to display these values) - Range 2 Down Level for Text: Black (or whatever color you want to display these values) - Range 3 Down Level for Text: Black (or whatever color you want to display these values) Then in the other Numbers Bars study, you would set it up for the positive values by setting the following: - Singe Value Text Alignment: Right - Range 3 Up Level for Text: Black (or whatever color you want to display these values) - Range 2 Up Level for Text: Black (or whatever color you want to display these values) - Range 1 Up Level for Text: Black (or whatever color you want to display these values) - Range 0 Up Level for Text: Black (or whatever color you want to display these values) - Range 0 Down Level for Text: Same as background - Range 1 Down Level for Text: Same as background - Range 2 Down Level for Text: Same as background - Range 3 Down Level for Text: Same as background For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
