Date/Time: Tue, 26 Nov 2024 00:49:47 +0000
Chart value/cross hair issue
View Count: 198
[2024-01-17 19:24:05] |
redtrader101990 - Posts: 2 |
I just connected live data today, and did the latest update to Sierra. I can no longer see the crosshair tool when I select it on my charts. Is there a fix for this?
[2024-01-17 22:15:28] |
John - SC Support - Posts: 36286 |
There is an issue in the release you updated to where the Crosshairs and Price/Time Boxes are changing the color to White, so if you have a white background, you will not be able to see them. You need to change the colors yourself, as when we have this fixed, it will just not change the color, but we do not know what your previous color was. The Graphics Settings items you will want to change are the following: - Chart Values: Color of the Price and Time Boxes - Chart Values: Crosshair For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
