Date/Time: Tue, 26 Nov 2024 00:54:56 +0000
E-MINI NATURAL GAS (NQG) Data history
View Count: 177
[2024-01-17 18:54:57] |
User579155 - Posts: 7 |
Hi, i used to use Denali data and Teton routing. In order to be able to trade EUREX, I needed to switch to CQG routing (while keeping denali data) but I am experiencing odd situation while loading historical e-mini nat gas data - I used to be able to load data from 2017, now it is only possible to load from 07/17/2023, while it is quite broken till at least 12/2023. I cannot find explanation for this, since I am still using Denali data. Can you please give me any insight on this? Should I provide further detail, please let me know. Thank you. |
[2024-01-17 22:10:40] |
John - SC Support - Posts: 36286 |
You definitely should be able to get data prior to July of 2023. Please go through the items at the following link and see if one of them resolves this for you: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
