Date/Time: Tue, 26 Nov 2024 00:43:22 +0000
data folder
View Count: 151
[2024-01-17 17:59:09] |
User565747 - Posts: 16 |
so am trying to use a temple chart layout and it says that i need to copy and paste it to the sierra charts folder on the data tab , but i dont see any sierra chart folders there , i have the sierra icon on the download tab on my pc , and the shortcut on my desktop only , how do i add it as a folder
[2024-01-17 18:17:47] |
John - SC Support - Posts: 36286 |
By default, your Sierra Chart folder would be located at C:\SieraChart, and the Data folder is then below that (so C:\SierraChart\Data). But you could have put the installation anywhere on your computer. If you open your Sierra Chart software and select "Global Settings >> General Settings >> Paths", and look at the entry for "Data Files Folder" it will tell you where the Data file is located for your setup. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
