Date/Time: Tue, 26 Nov 2024 00:51:59 +0000
Placing Two Different Line Studies in 1 Region
View Count: 203
[2024-01-17 17:53:13] |
Le Dharma - Posts: 73 |
Hey Sierra - I was wondering, if Sierra allows us to place two different studies inside 1 region, WITHOUT forcing the studies into a numerical position on the Y AXIS. So, normally, when two studies are put into 1 region, they fall into a number on the Y axis. If you put a spread difference of two MA's into the Price Region (region 1), the Region will display Price and Spread, one near the zero line, and one near the asset's price. It should look like two distance straight lines... Could Sierra display the MA and the Price as a percent change since the beginning of visible bars? If that were possible, I'm guessing we could see the Spread Difference and Price be displayed with great clarity. The Tops and Bottoms of the Spread Diff would occupy the tops and bottoms of the entire Chart region, and Price would not be some distance line. In this way, we could evaluate Studies with our Eyes, in a very easy way. Is this possible? |
[2024-01-17 18:12:30] |
John - SC Support - Posts: 36286 |
Refer to the following for how to set a study to be independent of the scale: Chart Scale and Scale Adjusting: Maintaining Same Scale for Multiple Graphs in Chart Region Also, refer to the following for how to use the Left Side Scale to be able to scale an independent study: Chart Scale and Scale Adjusting: Use In Left Side Scale For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
