Date/Time: Tue, 26 Nov 2024 00:54:18 +0000
Can't access RealTime CME data for 6EH24-CME/SPH24-CM inspite of having Service Package 12
View Count: 306
[2024-01-17 05:43:30] |
rkerketta1986 - Posts: 1 |
Hi Team, I have Service Package 12 but I am still not able to access CME real time data for 6EH24-CME/SPH24-CME. I raed somewhere that I need to have some sort of trading account in order to have real time data from CME. I did make an account in IronBeam, now they are asking to deposit $500 in order add my sierra chart account name. Please note I have chosen Sierra chart in order to access footprint chart and DOM to pass my Prop fund challenges. Please advice some alternatives in order to get realtime CME data. Thanks Robert Date Time Of Last Edit: 2024-01-17 06:04:58
[2024-01-17 06:05:30] |
Sierra_Chart Engineering - Posts: 17178 |
Yes: I raed somewhere that I need to have some sort of trading account in order to have real time data from CME.
Here is a solution which only requires a 100 USD account: Easy Solution to CME Funded Trading Account Requirement ---- The reason you are not getting real-time data from the Denali Data Feed, and historical data from the Denali Data Feed in the case of when using an external Trading service (Rithmic, CQG, Interactive Brokers), from the CME Group of exchanges is that you activated the *Non-Professional* exchange fees. However, you have not verified in the last month that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees. Refer to the "Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges" section here: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Rithmic paper trading or trading evaluator accounts are not considered a live funded futures trading account. Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees If you do not have a funded trading account or one with a supported Trading service, then refer to this solution: Easy Solution to CME Funded Trading Account Requirement Consider the above solution to avoid this problem in the future. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-01-17 06:05:45
