Date/Time: Tue, 26 Nov 2024 00:33:32 +0000
alert wording
View Count: 267
[2024-01-17 03:31:03] |
User702340 - Posts: 12 |
hi dear, would like to set up an alert in the analysis / studies / stochastic momentum indicator / alert as follows, can you pls help as i am tech-blind, alert if meet the following 3 criteria 1. 20ema>50ema; 2. price =<20 ema; and 3. -40 < stochastic momentum index < 0 exactly what should I input on the alert box to effect the above? thousand thx |
[2024-01-17 16:06:29] |
John - SC Support - Posts: 36286 |
The alert would look like the following: =AND(ID1.SG1 > ID2.SG1, C <= ID1.SG1, ID3.SG1 > -40, ID3.SG1 < 0) Where ID1 is the ID of the 20 EMA study. ID2 is the ID of the 50 EMA study, C is the Closing (Last) price, and ID3.SG1 is the Stochastic Momentum indicator. You would need to change the ID numbers we gave to match what these studies are set to in your chart. The Subgraphs should be correct, unless you are wanting the Stochastic Momentum Indicator Average, in which case you would need to change the SG reference for ID3 to be SG2 (ID3.SG2 rather than ID3.SG1). Refer to the following for reference: Study/Chart Alerts And Scanning: OR and AND Functions Study/Chart Alerts And Scanning: Available Main Price Graph Identifiers/Variables Study/Chart Alerts And Scanning: Referencing Study Subgraphs Study/Chart Alerts And Scanning: Referencing Other Studies on the Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
