Date/Time: Tue, 26 Nov 2024 00:31:39 +0000
SMH/SPY/IGV/US equities
View Count: 182
[2024-01-17 03:28:30] |
User243538 - Posts: 4 |
Hello Sierra support, I'm interested in real time data for ETFs such as SMH/SPY/IGV. Which package can i activate that would give me these symbols real time feed? Thanks |
[2024-01-17 16:01:20] |
John - SC Support - Posts: 36286 |
The package you would need is one of the "Integrated" packages, as you would need to be on one of these in order to have the ability to get the real-time data for our Denali Exchange Data Feed. Refer to the following: Description of Service Packages and Pricing: Integrated Packages We see that you are currently on Package 11, therefore you would not need to change. Then follow the instructions at the following link to setup the "U.S. Equities Consolidated Tape" exchange: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
