Date/Time: Tue, 26 Nov 2024 00:34:28 +0000
[User Discussion] - Calculator Vertical Align
View Count: 167
[2024-01-16 20:24:25]
User14953 - Posts: 236
Calculator and Vertical Line drawings compete for space and overwrite one another.
It's a significant time sink to rectify on low timeframe charts.
Want to set Calculator Vertical Align's 'Edge' setting to print One Line Down EDGE (-1) from the standard setting uppermost on the chart.
I like that the Edge setting provides visual cue where the longs and shorts fall out by where the label's located on the chart.
Could there be an option to set The Calculator Vertical Align setting: EDGE, to print One Line Down from the standard uppermost line setting and thereby prevent overwriting the Time Label?
Calculator EDGE (-1) would always print one line downward.
Vertical Line properties, Labels, Vertical Align TOP.
Chart Calculator properties, Labels, Multiline, EDGE (-1)
Date Time Of Last Edit: 2024-01-16 20:40:09
