Date/Time: Tue, 26 Nov 2024 00:35:56 +0000
Volume Value Area Lines
View Count: 178
[2024-01-16 18:25:58] |
User585993 - Posts: 83 |
why are the value area lines from the previous day dont show up, are my setting wrong?
[2024-01-16 19:41:30] |
John - SC Support - Posts: 36286 |
The way you have your Inputs set, you should be seeing Value Area Lines on the current day's bars, which represent the Value Area from the previous day. Are you not seeing this? Are you getting any lines at all?
[2024-01-16 19:55:33] |
I don't see any lines from the previous day
[2024-01-16 20:09:23] |
You can not use the Volume Value Area Lines study directly on a TPO chart. Refer to the following: Time Price Opportunity (TPO) Profile Charts: Using Other Studies on a TPO Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
