Date/Time: Tue, 26 Nov 2024 01:35:17 +0000
[User Discussion] - password, security
View Count: 349
[2024-01-16 17:50:01] |
User725043 - Posts: 35 |
Plan to move SC to a dedicated server in Chicago. Could you please provide any relevant information in regards to protecting against theft, of the autotrading system code (ACSIL DLLs and Study Collection settings), by the data center provider who will have physical access to the server? 1) If I login to SC but do not select save password will that stop the provider from gaining access to my SC interface/Charts, unless they are running a keylogger? 2) In the documentation found: sc.DLLNameUserServiceLevel; sc.IsUserAllowedForSCDLLName; and the Chart Studies: Password Protecting Studies in the interface. Is there any further similar functionality available that could be helpful for security? 3) Is it possible to encrypt the SC/Data folder, symmetric or asymmetric, and still retain proper functionality and performance for autotrading. Is there any guidance for this, and a preferred encryption method/software, perhaps open-source? 4) In the Chicago area, are there any dedicated server providers you could recommend for using Teton --> CME Aurora? |
