Date/Time: Tue, 26 Nov 2024 00:28:40 +0000
[User Discussion] - Change the color
View Count: 201
[2024-01-16 17:06:59] |
User699497 - Posts: 5 |
Hello, When I used the Hand tool, the color of the horizontal/vertical lines of the crosshair, the price, the time and the date were black (my chart´s background is white), but now they are white so I can't see them. I don't know what happened and I can't find where I can configure the color. Can you help me? Thank you. Paulo Andrade |
[2024-01-16 19:17:20] |
User540504 - Posts: 15 |
I have the same issue after updating to 2586. Please advise.
[2024-01-16 19:52:31] |
John - SC Support - Posts: 36286 |
This was an error on our part and will be resolved in our next update. But since you have already had the issue, you will need to change your colors back to what you want them to be. The particular Graphics Settings are the following: - Chart Values: Color of the Price and Time Boxes - Chart Values: Crosshair Keep in mind there are both global settings and chart settings, so if you have these set differently for some charts, then you will need to update them for each chart. Refer to the following: Graphics Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
