Date/Time: Mon, 25 Nov 2024 20:19:39 +0000
LMAX trading data
View Count: 255
[2024-01-16 11:34:05]
User418920 - Posts: 30
The trading data from LMAX does not update in my Sierra Chart user interface.
Its stays stuck at a certain point in time, and to update, I have to manually do a file/reconnect. After I have done that the data is updated once, but stays stuck at that update.
I also did a delete and download data and installed the newest version of Sierra, but that does not help.
How can this be solved?
KR
[2024-01-16 11:45:25]
Sierra_Chart Engineering - Posts: 17174
We are checking on this.
[2024-01-16 11:49:14]
We apologize for this. This is now resolved.
[2024-02-02 16:13:41]
the problem is re-appearing.
The trading data from LMAX does not update realtime in my Sierra Chart user interface.
Its stays stuck at a certain point in time and does not uptdate or updates only periodically.
Delete and download data does not help.
Can you look into this?
[2024-02-04 23:47:59]
Let us know if you are still having an issue?
