Date/Time: Tue, 26 Nov 2024 01:52:35 +0000
Delete button
View Count: 224
[2024-01-16 08:34:50]
Jimmyy - Posts: 221
Pressing the delete button more than once on my (apple) keyboard makes the tool go to pointer from hand.
I don’t want that to happen.
Another scenario is that lets say i drew a price retracement tool and immediately pressed delete button. The lines of price retracement shows multiple 0 instead of deleting the price retracement. So i press delete again and i think after i left click on the chart the price retracement gets deleted and because i pressed delete twice the tool switches to pointer (which i dont want it to happen)
I want the price retracement to get deleted after i press the delete button immediately after it was drawn.
If draw the price retracement and do some other stuff like move the chart around,etc(which involves left clicking) and then if i press delete on the retracement tool, it gets deleted properly.
[2024-01-16 11:32:58]
Sierra_Chart Engineering - Posts: 17179
Go to Global Settings >> Keyboard Shortcuts and see if there any commands the Delete key is assigned to.
Date Time Of Last Edit: 2024-01-16 11:33:12
[2024-01-16 14:06:04]
Jimmyy - Posts: 221
There is no shortcut assigned to the delete key. I also tried to assign the delete key to the hand tool but then I wasnt able to delete drawings from the chart
