Date/Time: Tue, 26 Nov 2024 00:53:07 +0000
Charting US Stocks With Sierra Chart?
View Count: 244
[2024-01-16 00:40:17] |
User344276 - Posts: 68 |
Is it possible to chart US Stocks/Equities with Sierra Charts? If it is possible, can you please provide instructions? Thanks.
Date Time Of Last Edit: 2024-01-16 00:41:52
[2024-01-16 14:31:37] |
John - SC Support - Posts: 36286 |
We have data for U.S. Stocks. Follow the instructions at the following link to setup the "U.S. Equities Consolidated Tape" exchange: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* If you need Market Depth data, then you would need to activate both the "U.S. Equities Consolidated Tape" and the "NASDAQ TotalView" exchanges, and then use a symbol with an "_MBO" suffix (e.g. IBM_MBO). This will combine the data from both exchanges to get you the full volume from the consolidated tape exchange along with the market depth from the TotalView exchange. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-01-16 22:51:43] |
I just added the "US Equities Consolidated Tape" exchange and I'm seeing an action result that includes a red x with a message stating "Exchange Agreements need to be reviewed by Sierra Chart Support." Is there anything else I need to do?
Date Time Of Last Edit: 2024-01-17 02:03:13
[2024-01-17 15:26:11] |
We see that the agreements have been accepted, so you should be fine now. If you are still having an issue, let us know.
