Date/Time: Tue, 26 Nov 2024 01:46:12 +0000
Need Help With Sierra Charts DOM and Getting Live Data on my Account
View Count: 222
[2024-01-15 22:58:15] |
User157547 - Posts: 15 |
First of all, is there a way to get live data without connecting a funded account? I only trade on TOS. Second, I have a created and designed a Footprint Chart study. How do you save that study and apply it to another chart? I have done the same with a DOM. Is there a way to save and apply that DOM to other charts/stocks? lastly, on the DOM I was hoping to find a Volume Profile Delta somewhere - Not as a volume graph, but the actual delta numbers being displayed in a column. Please respond with help or set me up on a video call to walk me through some of these steps. Thank you very much.
[2024-01-15 23:17:14] |
John - SC Support - Posts: 36286 |
For the CME Group data you have to have a live, funded, futures trading account that you can connect to in order to qualify for the non-professional exchange fees. If you do not have an account that you can connect to (such as TD Ameritrade) then we recommend the solution outlined at the following link: Easy Solution to CME Funded Trading Account Requirement The other option would be to pay the Professional exchange fees. I have a created and designed a Footprint Chart study. How do you save that study and apply it to another chart?
There are three options: 1) Use the Custom Stud Defaults to set the way you want the study to always come up every time it is used. Refer to the following: Chart Studies: Using Custom Default Study Settings 2) Use the Study Collections option to save it as a Study Collection and then use that on other charts. Refer to the following: Study Collections 3) Setup a "Template" Chart with the study on it the way you want it. Refer to the following: Using Chart Templates I have done the same with a DOM. Is there a way to save and apply that DOM to other charts/stocks?
A Trading DOM is just another chart. Therefore, you would use the Template method given above. lastly, on the DOM I was hoping to find a Volume Profile Delta somewhere - Not as a volume graph, but the actual delta numbers being displayed in a column.
You would need to use the Volume by Price study for this, where you would set the "Volume Bars Draw Method" to "Blank" and display the values you want for the study. Refer to the following: Volume By Price Study: Volume Bars Draw Method Volume By Price Study: Display Volume in Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
