Date/Time: Tue, 26 Nov 2024 00:41:25 +0000
Study Subgraphs Subtract/Difference
View Count: 205
[2024-01-15 20:34:51]
User411320 - Posts: 289
while using the Study Subgraphs Subtract/Difference, there is an input called "Study 2 subgraph offset", what does this mean? I saw the documentation of it but don't understand. is it like displacement?
[2024-01-15 22:57:55]
John - SC Support - Posts: 36286
Refer to the information here:
[2024-01-16 12:01:59]
Hello John,
I read the information and still don't understand
[2024-01-16 15:01:28]
It is an offset of the data. So if you want to subtract the data from study 2, but 3 bars back (so not current bar against current bar), then you would enter the value of 3.
[2024-01-16 19:53:53]
thanks
