Date/Time: Tue, 26 Nov 2024 01:51:22 +0000
cross hair disfunction
View Count: 220
[2024-01-15 20:28:14] |
CoolioDaddiyo - Posts: 3 |
I apologise for this trivial query, but the cross hair function is not working correctly on the charts. There should be horizontal and vertical lines so I can see price highlighted but instead I am getting a white band that is blocking out the price when I move it around the screen. I have tried installing again but that does not seem to work, neither does the update function.
[2024-01-15 22:56:51] |
John - SC Support - Posts: 36286 |
There was an issue with a few releases where the color of the Crosshairs and the Price/Time boxes got reset to their default, which is White for these items. It sounds like you are probably using a White background for your charts. You will simply need to change these items in the "Graphics Settings" in order to get them back to how you wanted them. This will be fixed in the next pre-release, such that when people update to that version they will not have this issue, but since you have already done it, you just have to change your colors. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
