Date/Time: Tue, 26 Nov 2024 01:33:40 +0000
Options
View Count: 186
[2024-01-15 16:52:12] |
User336233 - Posts: 3 |
Hello, is there any option or way to trade stock options from sierra charts to interactive brokers?
[2024-01-15 17:40:21] |
John - SC Support - Posts: 36286 |
Our understanding is that as long as you have the correct symbol, then this should be possible. Refer to the setup instructions to connect to Interactive Brokers at the following link: Interactive Brokers Trading Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
