Date/Time: Tue, 26 Nov 2024 01:27:28 +0000
[User Discussion] - Access TPO data from Study Subgraph Reference, or similar study...
View Count: 162
[2024-01-15 05:35:35] |
User895355 - Posts: 55 |
Is it possible to access the values from another chart's TPO study?
[2024-01-15 17:01:06] |
John - SC Support - Posts: 36286 |
There is no information that you can get from a TPO study directly through the Subgraphs. The subgraphs are there to set the color options, not to hold the data. If you are wanting items like the Value Area or POC, then it is best to use the "TPO Value Area" study on the chart where you want this information. Refer to the following: TPO Value Area Lines For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-01-15 19:19:04] |
ForgivingComputers.com - Posts: 960 |
The underlying Volume by Price values can be accessed with a custom study.
Date Time Of Last Edit: 2024-01-15 19:22:29
