Date/Time: Tue, 26 Nov 2024 01:33:21 +0000
Question about lmax spreads
View Count: 200
[2024-01-15 04:29:26] |
User886314 - Posts: 10 |
Hi Engineer, I would like to inquire about my lmax NZ account on sierra chart the spreads shown on the forex varieties are not correct, is this something I have to adjust myself on the sierra chart? How to adjust? Another question is that my LMAX suddenly won't connect to the host server, can you help me with that? Thank you for your help. Date Time Of Last Edit: 2024-01-15 04:57:25
_20240115124946.jpg / V - Attached On 2024-01-15 04:57:02 UTC - Size: 648.77 KB - 53 views |
[2024-01-15 16:41:54] |
John - SC Support - Posts: 36286 |
We need more information on the particular spread and what you are seeing. If you can give us a screenshot, that would be helpful. Follow the instructions at the following link for how to get us an image: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) We are not sure if the problem you are having connecting to LMAX is due to the US Martin Luther King Jr. Holiday. We see that LMAX does have some limited hours for trading today, so you should check to ensure that they are open for the times you are wanting to trade. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
