Date/Time: Sun, 23 Feb 2025 18:18:17 +0000
[Locked] - CLR vs Non-CLR version
View Count: 1840
[2014-07-31 01:45:07] |
rc7rader - Posts: 144 |
Hi, I only noticed today that there is a non-CLR version of SierraChart which doesn't use .NET and is recommended to new users. I don't use spreadsheet studies. Can I update to the non-CLR version without problems? Is there anything I need to reconfigure in SC's settings if I do so?
[2014-07-31 01:50:44] |
If you are not using Spreadsheets you can definitely use the non-CLR version without any issues and that is recommended. Nothing to reconfigure. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-19 10:09:37] |
User390494 - Posts: 1 |
MacOS users have two alternatives: CrossOver (with non-CLR) light, cheap and fast or Parallels (and Windows) but it is heavy and expensive (two licenses). When is the estimated release date for the SpreadSheet study in the non-CLR version? (translated)
[2021-02-19 10:32:25] |
58LesPaul - Posts: 429 |
If you are not using Spreadsheets you can definitely use the non-CLR version without any issues and that is recommended. Nothing to reconfigure. There is no "Download Latest Non-.NET Version" in my Help Menu. How else can I download this? |
[2021-02-19 10:36:55] |
When you say Crossover(with non-CLR) light, can I not use the CLR(spreadsheet) version of SC with Crossover? Also, Crossover light is Crossover One, the cheapest option, correct? Thanks |
[2021-02-19 11:00:19] |
This thread is from the year 2014. It is nearly 7 years old! It has no relevancy whatsoever. Sierra Chart no longer uses CLR. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-19 11:00:49
