Date/Time: Mon, 25 Nov 2024 13:29:20 +0000
[User Discussion] - Ninza KingRenko$ bar
View Count: 574
[2024-01-14 10:53:50]
Ticks - Posts: 183
Can the Ninza KingRenko$ bar be cloned with SC Flex Renko, the Flex Renko inverse, or any current SC bar types?
It uses the real OHLC of a candle.
This is the link to the KingRenko$ bar.
Date Time Of Last Edit: 2024-01-14 10:55:44
[2024-01-14 15:08:27]
User584084 - Posts: 262
Yes. Symbol SPX
Chart Settings >> Bar Period: Bar Period Type: Flex Renko Inverse Set, Bar Period Value: 25-5-50, Bar Period Bar New Bar Mode: New Trend Bar After Range Met | New Reversal Bar When Reversal Amount Met Plus 1 Tick and References Prior Close
For the Bar Period Value, I usually use a small value, typically 1 to 5 for the middle number and the last number is twice the 1st number.
Chart >> Graphic Draw Types >> Renko Brick With Wicks
Delta Divergence Study for the Arrow. Trend Following Mode (ln:4): No
https://www.sierrachart.com/image.php?Image=1705244868825.png
Date Time Of Last Edit: 2024-01-14 15:23:14
[2024-03-01 20:41:11]
BrianSaul - Posts: 1
Thanks for the info, any idea what you would set for NQ? Thanks in advance
[2024-03-01 22:02:26]
NQ Try 100-25-200 or 50-12-100
ES Try 20-4-40 or 10-2-20
