Date/Time: Tue, 26 Nov 2024 01:53:46 +0000
Help
View Count: 163
[2024-01-14 08:41:24]
User962594 - Posts: 1
Hello i have questions can you answer and help me please?
I think about to buy a subscribe 26$/month
So i want to know
1. I want it to trade forex and maybe snp500 and something like that , is this subscribe good for me?
2. I want to make chart with 4 windows , where i want to use : footprint , TPO and volume profile, cumulative delta and so on , is it also includ in this subscription? (I tried to sent the screenshot )
3. I want to ask about indicators
The first one is “delta” i mean horizontal delta , because I didn’t find it , how does it call?
The second is , i wanted to ask about any type of “cluster search or big trades” i saw how guys use circles , they called they *delta dot* or *volume dots+ I don’t know , but i also didn’t find it
4. I want to ask about connection.
I trade forex on BingX , and i use chart only for analysis, and open positions from my phone , so , i want to ask is it okay if i will not connect my broker account to sierra chart?
I mean , will chart change if i connect or won’t connect it? Or it’s doesn't matter and chart will be the same in all cases ?
[2024-01-15 16:00:48]
John - SC Support - Posts: 36286
1. The $26.00 subscription means that you would be getting the "Base Standard" package. On the "Base" packages, you are not allowed to connect to trading services or get any real-time data for the exchanges that require payment (which includes the CME Group).
Therefore, you would need to be on one of the "Integrated" packages in order to do what you want to do. Refer to the information on the packages at the following link:
Description of Service Packages and Pricing: Packages
2. You can definitely do this. But one item of note is that since you want Footprints (Numbers Bars) and TPO profiles, this further means that you would need to be on one of the Integrated Advanced packages.
To setup the windows, just arrange them as you want. Refer to the following options for things that can help with this:
Window, CB and CW Menus: Cascade (Window)
3. If you are wanting Cumulative Delta, then refer to the following:
Cumulative Delta Bars - Volume
If you are wanting Delta per Bar, then you would want to use the "Numbers Bars Calculated Values" study. Refer to the information here:
Numbers Bars: Displaying Numeric Information Below Numbers Bars
If you are wanting to view the Delta per price, then this is something you can get from the "Numbers Bars" study. Refer to the following:
Numbers Bars
For big trades, refer to the following:
Large Volume Trade Indicator
All of our studies are listed at the following link:
Technical Studies Reference
