Date/Time: Tue, 26 Nov 2024 01:46:31 +0000
Prop firm trading using Denali/Teton?
View Count: 581
[2024-01-13 23:17:42] |
User509533 - Posts: 57 |
Is there any prop firm that allows trading using Denali/Teton instead of Rithmic/Teton? Rithmic seems to unstable in recent days. |
[2024-01-15 15:40:30] |
John - SC Support - Posts: 36286 |
You can always use our Denali Exchange Data Feed with any Prop Firm, you just have to have a separate live trading account so you can qualify as a non-professional for the CME Group data. Refer to the following on this requirement: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges There are no prop firms that use Teton directly for their order routing, as Teton is only a live trading order routing system. But our Trading Evaluator service is used by Apteros, so you would be using our Denali data with them. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
