Date/Time: Tue, 26 Nov 2024 02:24:35 +0000
The Chartbook file is not compatible.
View Count: 222
[2024-01-13 19:23:32]
traderae - Posts: 4
Hi I need your help. When I try to upload chartbook. It says: The Chartbook file is not compatible. Contact Sierra Chart support for help with converting it. Can you please convert it with the latest version so I can open it without error please? See attached files
attachmentG7FXFOUNDATIONDOMCHARTBOOK-200330-085855.Cht - Attached On 2024-01-13 19:22:00 UTC - Size: 276.18 KB - 310 views
attachmentG7FXPROFOOTPRINTCHARTBOOK-200409-002540.Cht - Attached On 2024-01-13 19:22:15 UTC - Size: 528.28 KB - 112 views
attachmentG7FXSTAGE1PROFILECHARTBOOK-200608-010449.Cht - Attached On 2024-01-13 19:22:28 UTC - Size: 23.05 KB - 299 views
[2024-01-13 19:25:02]
traderae - Posts: 4
attachmentG7FXSTAGE2FINALCHARTBOOKALL-200608-010527.Cht - Attached On 2024-01-13 19:24:09 UTC - Size: 38.03 KB - 149 views
attachmentG7FXSTAGE2FINALCHARTBOOKCLONLY-200608-010527.Cht - Attached On 2024-01-13 19:24:44 UTC - Size: 16.59 KB - 220 views
attachmentG7FXSTAGE2FINALCHARTBOOKESONLY-200608-010527.Cht - Attached On 2024-01-13 19:24:54 UTC - Size: 22.15 KB - 106 views
[2024-01-13 19:25:35]
traderae - Posts: 4
attachmentG7FXSTAGE2WKLYVWAPPROFILECHARTBOOK-200608-011835.Cht - Attached On 2024-01-13 19:25:26 UTC - Size: 28.27 KB - 329 views
[2024-01-15 15:20:04]
John - SC Support - Posts: 36286
G7FX chartbooks have to be retrieved from G7FX. We can not help with this.
