Date/Time: Tue, 26 Nov 2024 01:59:12 +0000
Incorrect Data
View Count: 366
[2024-01-13 14:52:54]
L2Ltrades - Posts: 60
Please refer to the attached picture. I am charting NQH4.CME and my all time high is 17,702, which should be 17,165 I believe. How do I fix this?
imageNQ Incorrect data.PNG / V - Attached On 2024-01-13 14:52:12 UTC - Size: 43.44 KB - 53 views
[2024-01-13 15:26:17]
User431178 - Posts: 541
How do I fix this?
Don't use a back adjusted chart.
[2024-01-14 16:37:28]
If I do not use the back adjusted rollover, some data goes missing. There are gaps in the charts.
[2024-01-14 20:56:24]
The data isn't missing, you are seeing the price difference between contracts.
That is the trade off, gaps or calculated prices.
[2024-01-14 23:27:16]
Got it. Thanks!
[2024-01-16 10:50:48]
Sierra_Chart Engineering - Posts: 17179
Refer to:
Continuous Futures Contract Charts: Continuous Futures Contract Rollover Options
Date Time Of Last Edit: 2024-01-16 10:51:18
