Date/Time: Tue, 26 Nov 2024 02:39:32 +0000
Issue with Item Alignment in
View Count: 175
[2024-01-13 13:12:33] |
pierre.hh - Posts: 6 |
Subject: Issue with "Customize Chart DOM Header" Display in Sierra Chart Hi Sierra Chart Users and Support Team, I'm experiencing a small issue with the "Customize Chart DOM Header" feature. When I add items to the DOM header, they are displayed in a single line rather than line by line. This results in only a portion of the items being visible when my DOM is active. To view all items, I need to stretch the DOM to its maximum width, which is impractical. Is there an option available to configure the DOM to display items on separate lines? I've seen examples in various Sierra Chart documentation where items are displayed line by line, such as in this image: Sierra Chart DOM Example. Thank you in advance for your assistance. Best regards, PA |
Capture d’écran 2024-01-13 à 14.02.10.png / V - Attached On 2024-01-13 13:10:50 UTC - Size: 152.77 KB - 47 views Capture d’écran 2024-01-13 à 14.02.23.png / V - Attached On 2024-01-13 13:10:58 UTC - Size: 110.14 KB - 47 views Capture d’écran 2024-01-13 à 14.04.48.png / V - Attached On 2024-01-13 13:11:05 UTC - Size: 75.1 KB - 44 views |
[2024-01-13 15:27:50] |
User431178 - Posts: 541 |
Chart Settings: Autowrap Chart Header (Chart >> Chart Settings >> Display >> Chart Display Items menu)
[2024-01-13 17:10:15] |
User431178 thank you
