Date/Time: Tue, 26 Nov 2024 02:45:40 +0000
Have some .Cht files from version 2092 that are not compatiable
View Count: 236
[2024-01-12 22:34:19] |
User916869 - Posts: 1 |
I tried to load older chartbook files and get the warning that they are not compatible.n How can I convert these, or can i install that older version of SC? Thanks! |
[2024-01-13 00:37:41] |
Sierra_Chart Engineering - Posts: 17179 |
The instructions for this are here: Chartbooks (Workspaces): Opening Older Chartbooks Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
