Date/Time: Wed, 27 Nov 2024 04:53:55 +0000
account balances
View Count: 1404
[2014-07-30 23:16:03] |
User021827 - Posts: 174 |
I am using Sierra through AMP TT/net. Has anyone found a good way to check account balances and positions with this setup ? If not, does rithmic show this info when using Sierra ? CQG ? thanks Date Time Of Last Edit: 2014-07-30 23:19:49
[2014-07-31 04:07:55] |
Sierra Chart does not have access to the Account Balance when using AMP TT/net. When using Rithmic you will have the Account Balance. You should have the account balance when using CQG, although that has not been well tested. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
