Date/Time: Tue, 26 Nov 2024 01:52:34 +0000
Chart DOM not showing correct values for Daily H/L
View Count: 184
[2024-01-12 18:19:15]
Wernitschanton - Posts: 24
Hey Team.
I´ve set my sessions to only show RTH. My Chart DOM shows the ONL as daily Low and the current quote window also shows the Overnight Low.
What am i missing?
Best
Tony
[2024-01-12 19:43:19]
John - SC Support - Posts: 36286
Please give us an image of what you are seeing by following these instructions:
[2024-01-15 12:27:08]
Hey Team,
sure.
In the attached Screenshot you´ll see fridays high/low and on the chart DOM the H/L lines are different (Overnight io think)
Best
Tony
imageNQH24_FUT_CME MESH24_FUT_CME[M] 8.00 Range #9 2024-01-15 0.png / V - Attached On 2024-01-15 12:26:58 UTC - Size: 208.6 KB - 41 views
[2024-01-15 17:26:03]
What study are you using to get the High/Low?
[2024-01-16 08:14:32]
Hey John,
for the chart DOM i aint using any study. It´s the Daily High/Low Line from the Chart DOM graphics settings
Best
Tony
[2024-01-16 14:50:57]
The data for the Daily High/Low lines in the DOM comes from the Historical Daily Data, not from the Intraday data that is in the chart itself. The historical Daily Data may have a different High/Low due to the different times that it covers. Refer to the following:
Historical Chart Prices: 12.2 - Comparing High And Low In a 24 Hour Historical Daily Chart To an Intraday Chart
To get what you want, you would need to use the "Daily OHLC", "High/Low for Time Period", or "Period OHLC - Variable Period" study. Which one just depends on what you want from the study. But, none of these will show the line in the DOM, there is not a study that does this.
