Date/Time: Tue, 26 Nov 2024 02:27:26 +0000
attached oreder
View Count: 138
[2024-01-12 17:55:18]
User651547 - Posts: 59
HI. How can i add attached order Sl/Tp to current order ? I mean i plce order withot stop loss and after it want add it.
[2024-01-12 19:42:38]
John - SC Support - Posts: 36286
If you want to send the SL and TP after the initial order and have them associated with the primary order, then you would need to send them using the Order Type of "Send Attached Orders - Position/Price". Refer to the following:
Order Types: Send Attached Orders - Position/Price
Otherwise, if you just want them on the exchange, then you would send them as a Limit and Stop order at the prices you want. But these will not close each other out if one is hit.
