Date/Time: Mon, 25 Nov 2024 22:23:10 +0000
Existing drawings are not editable thru double clicking or right click properties V2584
View Count: 258
[2024-01-12 16:21:28]
THANOS929 - Posts: 23
The newest verision 2584 vs 2580
The ability to change an existing horizontal line by double clicking, single click and try to move, or right click and select properties, does nothing. version 2580 works. I imagine other drawings but not verified.
[2024-01-12 16:28:06]
John - SC Support - Posts: 36283
We are working on the issue of the Properties window not coming up.
But we are not able to reproduce any issue related to click and move the drawing. Can you give us specific steps you are taking.
[2024-01-12 16:37:28]
Yes u are correct, whether double click or right click to select properties, this doesnt work. You can single click it to select it and then move it.
[2024-01-12 20:17:22]
Sierra_Chart Engineering - Posts: 17175
This is resolved. Update to the latest prerelease:
[2024-01-12 20:29:16]
Disregard the prior message. This issue is not resolved yet. We are checking on it again.
Date Time Of Last Edit: 2024-01-12 20:29:25
[2024-01-12 21:01:42]
This is now resolved. Update to the current version of Sierra Chart.
