Date/Time: Tue, 26 Nov 2024 02:37:45 +0000
How to show ATR value in regional data line based on the candle I hover over?
View Count: 253
[2024-01-12 12:40:51] |
mojsterr - Posts: 26 |
I want to have ATR vale shown on top in the Regional data line, without showing the ATR chart on bottom. I have somewhat managed to make it work, but it now only shows today's ATR value. How to make it dynamic, so it shows me the ATR of the candle that I hover over? I want to check for yesterday's ATR and see it on top. Thank you. |
[2024-01-12 15:54:31] |
John - SC Support - Posts: 36286 |
We have answered this in the other post you had for this.
[2024-01-12 17:17:50] |
I already only made it happen with the search on this forum, but couldn't find the final thing. I'll check more thoroughly. Thank you.
[2024-01-12 19:22:36] |
Our apologies, there was apparently another post written at nearly the same time with nearly the exact same language and issue. But we see that this was not your post now. The only way to really view the ATR at each bar when you are moving your pointing device, is to use the "Tool Values Window". Refer to the following: Window, CB and CW Menus: Tool Values Window (Window) It sounds like you may have the "Chart Values Window" displayed instead, which only shows the most recent bar's information. Also, in order to view the data for a "Hidden" study, you would need to enable the option on the Subgraphs tab for "Display Values When Hidden". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-01-12 20:13:18] |
Thank you so much!
