Date/Time: Tue, 26 Nov 2024 02:23:58 +0000
ATR
View Count: 183
[2024-01-12 09:07:08] |
sahandprs - Posts: 11 |
Hello. I hope you are well. I want the ATR number to be displayed in Chart Value Windows for each candle. That is, if I move the mouse over any candle at any time, ATR will show me the same candle. Whatever I do, it only shows the last candle. What should be done? Date Time Of Last Edit: 2024-01-12 09:09:01
Screenshot 2024-01-12 123829.png / V - Attached On 2024-01-12 09:08:35 UTC - Size: 10.35 KB - 69 views Attachment Deleted. |
[2024-01-12 15:35:07] |
John - SC Support - Posts: 36286 |
If you are only seeing the most recent bar's value when you move your crosshairs to other bars, then this means that you have the "Chart Values Window" open. You need the "Tool Values Window" instead. Please select "Window >> Tool Values Window" to make the change. For information on these options, refer to the following: Window, CB and CW Menus: Chart Values Window (Window) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
