Date/Time: Tue, 26 Nov 2024 02:33:08 +0000
Deleting Residual Data from Discontinued Trading Service in Sierra Chart
View Count: 177
[2024-01-11 23:31:37] |
User951086 - Posts: 23 |
If I've discontinued the use of a Trading Service previously connected to Sierra Chart, how can I remove the chart data automatically downloaded by the system during the Translate Symbols process when connecting to that service? In my case, I initially connected to the "Interactive Brokers (Live Trading)" trading service, but I no longer use Interactive Brokers. Therefore, I would like to delete any residual data files that might exist in my computer system from the translation of chart symbols during my connection to the Interactive Brokers Trading Service within Sierra Chart. My intention is to clean up any unnecessary files and avoid retaining redundant data in my system. |
[2024-01-12 00:31:06] |
Sierra_Chart Engineering - Posts: 17179 |
Refer to: Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
