Date/Time: Mon, 25 Nov 2024 21:59:30 +0000
Stacking numbers frequently equal to bid size not change
View Count: 391
[2024-01-10 19:23:14]
User229477 - Posts: 35
The stacking numbers are frequently equal to bid size and don't reflect change. Usually it is only one price where stacking = bid and the other prices reflect the change properly.
[2024-01-10 21:15:01]
Sierra_Chart Engineering - Posts: 17175
What symbol do you notice this with?
[2024-01-10 21:23:33]
ESH4 I will have the stacking right next to the bid depth and about once every minute or two, I see the two equal, and all the other numbers are proper. I saw it less frequently on the ask size.
[2024-01-11 15:37:42]
John - SC Support - Posts: 36283
Is it the entire Pulling/Stacking column that is the same as the Bid/Ask or just some of the numbers?
When this occurs is it just for an instant, or how long does it last?
[2024-01-11 15:56:40]
It is for an instant and just some of the numbers.
[2024-01-11 20:00:45]
We want to make sure you are receiving the Denali Data Feed for that symbol.
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
Date Time Of Last Edit: 2024-01-11 20:02:01
[2024-01-12 04:19:14]
I just sent the message log to you as requested.
[2024-01-17 20:58:48]
In the latest version of Sierra Chart there are two new settings in Global Settings >> Chart DOM Settings:
"Limit Maximum Pulling Stacking Value To Current Depth Quantity" (Try setting this to No)
"Add Trade Volume To Pulling Stacking Value For Price" (You can also set this to No if you want to and have a look at what the result is)
We would recommend reconnecting to the data feed in each case with File >> Reconnect.
Pulling and stacking calculations are not perfect because of how data feeds behave and work.
Date Time Of Last Edit: 2024-01-17 20:59:34
[2024-01-24 07:10:28]
User513390 - Posts: 49
I am using Denali Feed
I have also an issue, as the bid size and buy column is empty.
Pulling and stacking showing only 2 price even though:
"Limit Maximum Pulling Stacking Value To Current Depth Quantity" (No)
"Add Trade Volume To Pulling Stacking Value For Price" (No)
whereas in the dom setting it is set to 15.
Can you help me please
[2024-01-24 07:10:29]
[2024-01-24 16:09:49]
You state the following:
So are you getting any Market Depth data in the DOM?
[2024-01-27 16:28:54]
It was working fine for 1 year and out of the blue it went empty last week.
I uploaded a picture of what my DOM looks like now.
Thank you for your help
image20240123_081344.jpg / V - Attached On 2024-01-27 16:27:02 UTC - Size: 5.65 MB - 68 views
[2024-01-29 16:24:13]
The reason you are not getting real-time data from the Denali Data Feed, and historical data from the Denali Data Feed in the case of when using an external Trading service (Rithmic, CQG, Interactive Brokers), from the CME Group of exchanges is that you activated the *Non-Professional* exchange fees. However, you have not verified in the last month that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees.
Refer to the "Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges" section here:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
Rithmic paper trading or trading evaluator accounts are not considered a live funded futures trading account.
Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees:
If you do not have a funded trading account or one with a supported Trading service, then refer to this solution:
Easy Solution to CME Funded Trading Account Requirement
Consider the above solution to avoid this problem in the future.
[2024-01-31 09:04:32]
SO i have to connect to CQG Live account once a month or ScSC Data - All Services?
[2024-01-31 16:33:53]
You need to connect to your live CQG account at least once a month to verify your non-professional standing.
Follow these instructions to connect to your CQG account:
CQG Trading Platform Service: Setup Instructions
The instructions to connect once a month are here:
