Date/Time: Tue, 26 Nov 2024 02:49:44 +0000
Duplicate chart to chart book is not working. V2583 pre release
View Count: 163
[2024-01-10 10:37:52] |
jmftattoo - Posts: 94 |
Title says it, I click duplicate chart chart to chart book and the drop down window starts to pop up then disappears completely. Not able to duplicate outside of the current chart book the chart is located within. |
[2024-01-10 16:33:27] |
John - SC Support - Posts: 36286 |
This is being looked into.
[2024-01-10 16:45:41] |
Sierra_Chart Engineering - Posts: 17179 |
This has been resolved. Update to the latest prerelease: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
