Date/Time: Tue, 26 Nov 2024 02:35:51 +0000
Interactive Brokers Order Cancelled / changing symbols
View Count: 179
[2024-01-10 09:36:55] |
User229477 - Posts: 35 |
Hello, I copied 2 cht files from my Stage 5 instance to Interactive Brokers instance. I realized the symbol mismatch so I used "change symbol" function for each window. Is there a way to change all the symbols in all the windows at once to Interactive Brokers format instead of doing individually? Date Time Of Last Edit: 2024-01-10 16:14:09
[2024-01-10 16:24:27] |
John - SC Support - Posts: 36286 |
Select "Edit >> Translate Symbols to Current Service" and it will do this for all charts in all open chartbooks. Refer to the following: Edit Menu: Edit >> Translate Symbols To Current Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
