Date/Time: Tue, 26 Nov 2024 02:44:49 +0000
[User Discussion] - Multiple Displays
View Count: 247
[2024-01-10 06:23:58]
Jimmyy - Posts: 221
This is question out of SC. Hope if someone Can help.
Here is how it goes : I have 3 monitors connected to my MB and I now need 1 more monitor but dont have any ports to connect it to. So i am thinking to get a GPU and connect my 4th monitor to the GPU. but before i purchase i want to make sure if 3 displays are connected to my motherboard and 1 display is connected to my GPU, will I be able to use them all altogether and extend it however i want in settings ? Or is it such that in a computer I can only connect all the displays either to the motherboard or the GPU? (like only be able to use the ports of either the MB or the GPU or I can use them both interactively). That's what I unsure of.
Thank you
