Date/Time: Tue, 26 Nov 2024 00:19:49 +0000
rithmic chicago area server for Funded Futures Network
View Count: 507
[2024-01-09 21:19:30] |
mikebarrels - Posts: 7 |
in the data/trade server settings, it has all kinds of different options for the funded futures network rithmic connection- all over the world. but it does not have chicago area. it exists, because that's the one i use when i sign in on the rithmic page. any chance you can add it or let me know if it's never going to be an option? thank you |
[2024-01-09 21:24:50] |
John - SC Support - Posts: 36286 |
The list of servers for Rithmic connections comes from Rithmic. Therefore, you would need to ask them about any missing servers.
[2024-01-10 14:36:51] |
User748811 - Posts: 18 |
to Mikebarrels: which data feed do you use now? Denali or Rithmic?
[2024-01-10 15:50:03] |
I used the Denali for a long time but FFN gives level ii for free so now I just have Sierra pkg 11 with rithmic data from FFN
[2024-01-12 07:53:20] |
Thanks for reply 1. I believe that Denali is better than Rhythmic for SC client in USA, but because of special network reason in China, Rhythmic maybe better solution for SC client. There are Asia gateway in Rhythmic. At the same time, I need to use multiple platform ,such as Multicharts, so more open Datafeed and add-on feature is edge. So question is: Can I use Rithmic feed+ SC+Rithmic order route now?(only no support from SC) 2. By the way, is FFN broker or FCM? What is full name? |
[2024-01-19 05:13:41] |
Sierra_Chart Engineering - Posts: 17178 |
Yes Rithmic is supported: Can I use Rithmic feed+ SC+Rithmic order route now?(only no support from SC)
Including their data feed, but there will be issues using the Rithmic data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-01-19 05:14:02
[2024-01-19 10:51:57] |
Rithmic support is like, non existent apparently. Still no response regarding the Chicago gateway. So I tried connecting to the rithmic/funded futures network Cape Town gateway (I’m in the US) and there was a two second delay on all order entries and modifications. If I subscribe to Denali data, but send orders to rithmic, would I still likely see huge delays in the executions like that?
[2024-01-19 16:16:32] |
We can not say for sure, as we do not know how Rithmic works. We would expect that you would see the same delays for orders, as the order should just be the order and should not have any dependency on the data.
