Date/Time: Tue, 26 Nov 2024 02:37:59 +0000
Numbers bars showing all zeros
View Count: 199
[2024-01-09 21:02:05]
User503208 - Posts: 2
Hi, I bought a new laptop and downloaded Sierra Chart, CQG etc etc and just tried to setup my chartbook / numbers bars as I had it on my old laptop (I trade the mini Nikkei 225). However, every bid and ask volume is displaying as zero. I've tried a few things to no avail. Am I missing something simple that should be updated on my new laptop? Many thanks
Date Time Of Last Edit: 2024-01-09 21:02:49
[2024-01-09 21:23:39]
John - SC Support - Posts: 36286
The most common reason for this is that you have a Daily or higher timeframe chart. The Numbers Bars study will not work on that data, as the Bid/Ask data is not present. You need to use the Intraday data.
Which Mini Nikkei 225 symbol are you using? There are several options over a few exchanges, so we need to know which one you are using.
