Date/Time: Tue, 26 Nov 2024 02:34:32 +0000
Data normalization & data mismatch
View Count: 237
[2024-01-09 19:36:50]
User825281 - Posts: 14
Hey, I'm wondering how you normalize the data when the contract rollover is/isn't applied.
We have some data mismatches between Sierra's data and other data provider we're using, and we're trying to figure out how to solve it using the same adjustment method which is used in Sierra's feature.
Thanks and have a great day :)
[2024-01-09 20:52:49]
John - SC Support - Posts: 36286
Refer to the following, which gives information for how to view the back-adjustment value that is used for each contract:
Continuous Futures Contract Charts: Controlling Rollover Amount for Back Adjustments
