Date/Time: Tue, 26 Nov 2024 02:51:01 +0000
New candlesticks have stopped being formed
View Count: 163
[2024-01-09 18:07:42] |
User142067 - Posts: 12 |
I am using 2 screens. The main one that I trade on periodically stops adding new candlesticks. I can see the priceline I have added continue to move though. The other screens are working and continue to add candlesticks. The problem is not that there are new candlesticks at the far right out of sight having already checked that. I have left the screen in the frozen state in case it will be helpful should help be available. I am willing to pay to find the solution if necessary.
[2024-01-09 18:38:39] |
Sierra_Chart Engineering - Posts: 17179 |
We can give you a call to look at this but most likely this is due to the Session Times: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart: 3.3 - Session Start Time and End Time not Covering Current Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
