Date/Time: Wed, 27 Nov 2024 04:52:02 +0000
2 color alert
View Count: 1022
[2014-07-30 15:55:43] |
jaban - Posts: 66 |
Hi I make a simple alert for a crosover of 2 EMA's is there a way that the color bar based on alert condition" , ========= will get a different color when the cross EMA 1 > EMA 2 and vv . thanks jaban |
[2014-07-30 16:04:20] |
You need to use 2 Color Bar Based On Alert Condition studies.
