Date/Time: Tue, 26 Nov 2024 02:35:50 +0000
data usage
View Count: 208
[2024-01-09 15:49:20] |
jakeybleez - Posts: 56 |
hello, i was curious and couldnt find anything about if a chart window is using data and or computer resources when it is minimized. example: a chart with a DOM/market depth window detached but is minimized. ex 2: charts in your chartbook when your chartbook is minimized. i always assumed if my cb is minimized the charts in there arent using as much resources. any info would be GREATLY appreciated!! -jb |
[2024-01-09 17:56:26] |
Sierra_Chart Engineering - Posts: 17179 |
Yes, a minimized chart, uses much less CPU time. Close to 0%. You can actually observe this in the latest prerelease. Update to the latest prerelease: Software Download: Fast Update And then go to a chart and open Chart >> Chart Settings >> Performance. Minimize the chart and then you will see the Average Calculation and Draw Time gradually go to zero. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
