Date/Time: Tue, 26 Nov 2024 02:38:11 +0000
Countdown Timer makes unwanted Alert Manager entries
View Count: 164
[2024-01-09 14:54:06] |
User14953 - Posts: 236 |
How can I get the countdown timer to chime when 10 seconds remains on a bar without getting unwanted Alert Manager entries? I entered the formula =SG1<=10 in the Alerts >> Alert Condition box on the Study Settings window. This works great but for the unwanted Alert Manager entries. How can I get the countdown timer to chime when 10 seconds remains on a bar without unwanted Alert Manager entries? Countdown Timer |
countdown timer alert mgr.png / V - Attached On 2024-01-09 14:53:07 UTC - Size: 75.59 KB - 58 views |
[2024-01-09 17:45:58] |
Sierra_Chart Engineering - Posts: 17179 |
You cannot remove the Alert Manager lines. But if the Alert Manager is automatically opening let us know.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-01-09 17:46:09
