Date/Time: Tue, 26 Nov 2024 02:25:48 +0000
study angle
View Count: 248
[2024-01-09 14:04:00]
User278398 - Posts: 291
hello,
i want to check the angle (slope) of formula i have.
(i got line, which built with spreadsheet formula study).
with the study angle, i cant reference that formula i built.
do you have a solution for my problem ?
thank you
[2024-01-09 18:54:10]
John - SC Support - Posts: 36286
We are not seeing any issue with using the "Study Angle" study with the "Spreadsheet Formula" study. Are you setting the "Based On" to the Spreadsheet Formula?
Refer to the following:
Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study
[2024-01-11 09:07:12]
work perfectly,
thank you
