Date/Time: Tue, 26 Nov 2024 02:19:54 +0000
Vertical Line stops 3 ticks before candlestick
View Count: 130
[2024-01-09 07:37:34] |
Piotr Grzegorzek - Posts: 21 |
Is it possible to have a vertical line stop 3 ticks before a candlestick and begin 3 ticks beneath it an than stop 3 ticks before the volume bar? See attached picture. |
Sierra Chart 2024-01_09_0834.JPG / V - Attached On 2024-01-09 07:36:55 UTC - Size: 48.71 KB - 50 views |
[2024-01-09 18:26:15] |
John - SC Support - Posts: 36286 |
You would have to either use the standard Line drawing and draw multiple lines for each bar you want to mark, or you would have to create a custom study to do what you want. Refer to the following: Chart Drawing Tools: Line, Ray, Extended Line Using Drawing Tools From an Advanced Custom Study List of Third Party Sierra Chart Study and System Programmers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
